stucco questions
Old 01-30-07, 03:30 PM
stucco questions
I have a couple of questions. I currently have smooth stucco on the exterior of my house, i would like to have the stucco that looks like knock down. Is that sprayed on or how is the easiest way to achieve that and do i use a bonding agent or 3 layers or what. also part of the front of my house is painted brick, i was told that you can stucco over the brick and make smoot or whatever, what is the best / easiest way to do that. thanks in advance.
Old 01-30-07, 05:17 PM
T
More info needed.
What type of stucco do you have, synthetic (thin and plastic-ish) or cementious (thick and rough below the finish coat)? Everything else will flow from that. Remove an exterior electrical plate, and you should be able to tell.
Old 01-31-07, 08:24 PM
i believe that it is Cementious stucco.
Old 02-01-07, 05:07 PM
T
If it is integrally colored, you are in good shape. If it is painted, you have to prep it. The more info you can offer the better, and photos are great.
Old 02-01-07, 05:52 PM
ill try and post pics later. It has been painted, and half of the house is smooth and the other is brick that has been painted over.
