How Much Mortar To Mount Mantel?
Old 02-13-07, 08:18 AM
We Are Putting In A New Mantel Made Of Sandstone.how Much Mortar Do I Use On Top Of The Bricks Before I Lay It On Top So I Get That 1/2 Inch Joint(nomenclature?) Between The Brick And Mantel?the Mantel Is 7 In.deepx 2 1/2 In Thickx 7 Ft Long.am I Correct To Use Mortar?if Not What?anyones Help Would Be Great!
Old 02-13-07, 06:54 PM
T
Not enough info. How far does the mantle extend beyond the brick face. What is the height of the space in the brick face. Ne construction or old. Etc. Photos and/or diagrams would make it simple.
Old 02-13-07, 08:34 PM
Frank99's Avatar
Use mortar 3/4" thick, mixed to consisity of peanut butter, Press the mantle down and level. Tool the joint.
Frank
Old 02-14-07, 01:40 PM
The Mantel Extends 3 1/2 Inches With 3 1/2 Inches Resting On The Existing Brick.There was Some Motar Behind The Old One And Has Been Removed.The old mantel was resting on two supports made out of brick that extend out on each end so there was 6 inches of mantel resting on them.I Think 3/4 Inches Thick of mortar was what I am looking for.So If I Put A 3/4 Inch Layer Of Mortar,1/4 Of An Inch Will Be Displaced?am I Correct In Saying That?thanks.
Old 02-14-07, 08:38 PM
Frank99's Avatar
Correct, it will compress and some will squeeze out. Depending on how wet your mortar is its a guideline. If it goes down to much, reset it with more mortar, too high reset it with less mortar
Old 02-15-07, 05:59 AM
Thanks for your help,I appreciate it.I'll let you know the outcome.
