Brick Front Door Step
Old 04-22-07, 11:43 AM
C
The Brick Front Door Step on my house is breaking apart. It is 76" by 48". Made of standard 8' Red brick. Two layers of Brick, with a coat of mortar between the two. The Bottom layer seems fairly secure,although a couple of bricks at the edges are loose. The top layer is breaking up at the mortar joints with Bricks coming away in my hand.
I have never done any Brick work, but have done almost everything else.
Wher should I begin with this project. Should I replace all the Bricks with new or can you remove the mortar and re use the old.
Maybe I should look at a Different design for the step. The Door is only 16" from the ground.
Thanks
Old 04-22-07, 11:52 AM
Received 840 Upvotes on 737 Posts
If you replace the brick with new, they may not match. It is a fairly simple job to clean of the old mortar and reset the bricks with new mortar.
