garage foundation
Old 05-10-07, 03:44 AM
psrs0810
garage foundation
We want to build a 2 car detached garage in the back of our house. We have an existing garage attached to our home which is too small.
From the alley our driveway slopes towards the house by about 3 feet. Is it possible to build that up in flits, compacting it. Then when I get to final grade have someone pour the foundation for the garage?
We are located in PA, so we do get freezing temps. Is there a way to build the foundation with out having to build 3 foot perimeter walls?
Thanks
Old 05-10-07, 04:44 AM
AxlMyk's Avatar
Was it really neccessary to double post?
Old 05-11-07, 03:38 PM
C
Are you going to extend the existing garage or pour a new floor separate from the house? Your attached garage has a foundation poured with the house I can guarantee that, so if you add-on to it you MUST have a foundation as well… one can get away with just corner foundations of the attached garage that are below the frost line but I would speak to your local village inspector first.
If it is a separate slab that one can go with a floating slab without a foundation.
As for your base, compact it at 6” lifts and use a gravel base with screenings that compacts well, and let it sit for a month or so if possible before the final grade and pouring of the concrete.
