Screw holes in patio slab
Old 06-05-07, 06:49 PM
R
I removed brackets from my patio slab. There are 1/4 inch holes left in the concrete from the screws.
What is the simplest fix for these holes to avoid cracking from water and freezing?
Thanks
Old 06-05-07, 07:27 PM
XSleeper's Avatar
Received 1,923 Upvotes on 1,727 Posts
Caulking that is meant for cement crack patching (rated for vertical surfaces, so that it is more like caulk, not strictly for horizontal surfaces, like some self-levelling sealants are). I hesitate to recommend a self-levelling sealant, since they are usually very runny and you could easily make a very big mess with it if you've never used it before.
Old 06-06-07, 01:49 PM
R
Thank you. I will head down to Ace Hardware tomorrow and ask them about this product.
