Concrete Slab Skim Coat for Garage
Old 10-04-07, 12:36 PM
T
Disclaimer: First Posting. Hoping for success.
Question: I am contemplating a skim coat of concrete over my two car garage concrete floor. The existing floor is in good shape; however, water from snow melt does not flow to the floor drains and therefore create large puddles on the floor.
What is the absolute minimum thickness I could get away with and still have confidence it will not crumble under the weight of a couple standard passenger vehicles? Thanks, TCM.
Old 10-04-07, 03:49 PM
P
It depends on what you're skimming it with. Whatever product you use will have instructions on the bag, including application thicknesses, etc. Don't just try to use a sand topping mix, because that will crack and flake away in short order. Whatever you use will have to be a polymer fortified concrete mix of some sort. It will most likely require an acid etch, and a primer coat before application. Good luck.
Pecos
