Brick wall through bolts- how much load?
Old 10-04-07, 04:07 PM
L
We are thinking of hanging heavy punching bags from custom made steel brackets on the inside of an exterior brick wall, securing them with through bolts to a metal plate on the outside. We plan to use 1x12 as a washer between the interior bracket and the brick. The bags will be taking a lot of abuse, kicks and punches, a lot of violent swinging. Has anyone tried this? Will it hold, and the metal plates serve to dissipate the wiggle, or will it damage the supporting brick wall?
Old 10-06-07, 03:46 PM
Received 1 Upvote on 1 Post
Is the wall a real (solid) brick wall or just brick veneer over a stick wall?
If it is veneer, you probably have wall ties separating the wood and brick that could collapse/compress due to the tightening of the through bolts and from the impact and vibration - it is not just a question of the load, but the wall construction.
If it is a real brick wall, you should have no problems.
Dick
Old 10-06-07, 08:28 PM
L
It is solid brick, thanks for the answer.
