Repair/patch a concrete joint in the cold weather - how to?
Old 12-17-07, 09:10 AM
Q Brizzle's Avatar
Hi all, I need some help repairing a joint under the top step of the front entryway to my house. The top slab is actually over the corner of the basement, which is odd, but that's another topic.
The issue is this joint between old and new concrete, as seen in the photo below:
The previous homeowner is a mason, and did a lot of concrete and brick work around and inside the house. In 1999, he repaired/resurfaced the entry steps. The concrete under the "lip" is actually the top of the foundation. The concrete in the foreground is the second step. The concrete on top is the top step.
It doesn't look like it from this picture, but cold winter air is entering the basement through this crack/joint. This basically runs the entire perimeter of the top step...and I know this is happening because I'm getting frost in the basement directly on the other side of this concrete.
I need to patch this, asap. Any ideas what will work in the sub-freezing weather? I'll consider anything that is close color-wise...so if something elastomeric or asphaultic comes in "gray", it should work. I just need to stop the air coming in, then I can insulate from the basement side.
Your thoughts are welcome. Thank you.
Old 12-17-07, 03:50 PM
thought you might've,,,
gotten enuff answers in the other forum,,, wait til warm weather & then fix it.
there are elastomeric coatings that'll resolve the color issue 'tween the old & new conc,,, sonneborn & thoro both make good products.
Old 12-18-07, 06:30 AM
Q Brizzle's Avatar
English?
There weren't many replies in the "Basement" forum about fixing the concrete, that's why I came here with my problem.
Waiting until spring is an option, but why not tackle it now, save some energy, and prevent more damage?
Old 12-18-07, 12:57 PM
T
I would expandofoam it to stop the air, then fix it properly in the spring.
Old 12-19-07, 06:29 AM
Q Brizzle's Avatar
That's what I've decided to do. I'll squirt foam in between the plywood form and the top of the foundation as best I can. Then, I've got some R10 2" thick XPS I will use to block off the interior side of this structure, hopefully keeping the relatively warm basement air from colliding with whatever air still comes through the crack in the concrete. In the spring, I'll patch the concrete thoroughly and check the basement structure to make sure moisture isn't a problem.
Thanks.
