Base for Lamp Standard
Old 01-28-08, 11:02 AM
P
Received 1 Upvote on 1 Post
Last July (2007) the last of my 3 Aspens blew over.
This March I want to install a nice light standard where the trees used to be. I assume I need a concrete pad. The links below help visualize a couple of considerations, namely:
1. The area is on a slight slope.
2. I get significant soil shifting during the winter. The adjacent driveway slabs rise and fall about an inch, high in Jan/Feb and leveling out in July.
3. The soild is bentonite. Harder than concrete when dry, slipperier than snot when wet.
4. Do lamp standards have a standard (no pun intended) mounting template?
I want to use a concrete pad upon which I can install the standard.
Main concern: I don't want the light pole to lose its plumb as the seasons change and the ground freezes and thaws.
Question 1: How thick should the pad be? It will be around 4 to 5 feet in diameter to cover the dirt you can see in the pictures.
Question 2: When should I dig the hole in preparation for the foundation? I was thinking as soon as the ground unfreezes (I live in Colorado on the western slope).
Question 3: I'll buy the concrete at Lowes, but I don't know what kind to buy - post mix? Something else?
Any other considerations I should be aware of? The electrical is already in, BTW.
http://pipsisiwah.home.bresnan.net/i...5_008lores.jpg
http://pipsisiwah.home.bresnan.net/i...5_009lores.jpg
http://pipsisiwah.home.bresnan.net/i...5_010lores.jpg
Old 01-28-08, 11:48 AM
T
Your pictures don't show as linked.
However, FYI, the way you posted them is highly insecure:
You graduated from UCLA, HD from the Army, your name is Clayton, etc.
Old 01-28-08, 03:05 PM
P
Oops. Forgot the underscore before the "lores". Try these:
http://pipsisiwah.home.bresnan.net/i..._008_lores.jpg
http://pipsisiwah.home.bresnan.net/images/20070725_009_lores.jpg
http://pipsisiwah.home.bresnan.net/images/20070725_010_lores.jpg
Not sure how to plug the leak you found. Did you get to the place where it tells my jock size?? I should place an .htaccess file in my folder there, but I don't know if I can do that at Bresnan. Can you summarize the trail that led to the other info? That way I'll know where to start putting the cybercaulk...
Old 01-28-08, 03:13 PM
T
Just put an index.htm file in the parent directory.
Old 01-28-08, 08:30 PM
P
Let's try this one more time. I edited the uris in the above box to point to the correct images.
I oughta have my head examined for considering a lamp standard when I can't even get a couple lousy links right...
Tscarborough,
Thanks for the heads-up. I added an index file to each subdirectory.
