how to square up concrete stoop
The aggregate concrete steps/landing on my rambler is poured out of square. The outside edge is +/- 1" from the house wall. That is, there is a total of 2" difference in the dimensions from the house. I need to square it up in order to lay concrete pavers so they come out even.
I had the ideas to square it up by skim coating several times on the outside front wall of the stoop or to pour a few inches of concrete extension. My concern is that either method might not stick or would crack over time. I need it to be as solid and immovable as the stoop. Which method would be better or is there another method?
If I poured a concrete extension, how would I hold it to the existing sidewall? Drill holes and drive in rebar, or concrete nails or what?
Pavers
Install the pavers on what you have. Start on the outside edge and work toward the house. Cut the last row next to the house to fit the space.
