Sealcoating driveway
Hello, I'm Planning on sealcoating my driveway this spring, and had a couple of questions.
1. How often should a driveway be sealed?
2. Should I use latex or oil based sealer.
Any help would be greatly appreciated.
I assume this is an asphalt driveway.
#1 - 1-3 years, depending on how it wears.
#2 - I have a friend in the driveway sealing business and he always uses the water based sealer. Presumably it's better, I know the clean up is easier
Hi Boater,
I used a sealer by Quikrete for the drive. Mine is about 120 foot long, 12 foot wide, except for the last 30 feet, when it is double wide. I had just a cup or so leftover out of a 5 gallon bucket.
To apply, I just tipped the bucket, poured a pool and spread with a 24" roller. Worked great (except for the part where the drive heads downhill and I had to chase after the sealer!)
I finished in about an hour.
I don't recall if it was water based, but you can still see water bead after 2 years.
Connie
Connie
