Blue Painters tape left stains on concrete floors
Hi,
I just uncovered my concrete floors which had 2 layers of building paper during construction and discovered that the blue painters tape that held the paper to the floor bled in a few places. I tried scrubbing it out with TSP but this only worked a little.
Can anyone recommend a stain remover that won't leave a residue? Or should I try and grind/sand the stains out?
Thanks,
/Doug
Thanks,
/Doug
Marksr,
Thanks for the reply. I'm wondering if paint thinner will leave a residue that might subsequently show up when the concrete is painted with a soy-based stain (soycrete)?
3M says: "If you encounter problems with Painters' Tape, please contact 3M customer service at 1-800-494-3552."
As part of soycrete's recommendations for surface prep, they recommend ecoprocote Eco-Etch<SUP>tm</SUP> Gel Concrete Etch & Sealer Remover. This product etches to the depth of same as hydrochloric or muriatic acid and should solve your dye bleed in concrete problems.
http://www.ecosafetyproducts.com/Eco...ee3-7000-1.htm
SoyCrete<SUP>tm </SUP>Instructional DVD (28 minutes) and lots of links to helpful info can be found here: http://www.ecosafetyproducts.com/Soy...p/s9-scv-1.htm
