Grass + Ashpalt
Old 04-23-08, 09:54 AM
O
Grass + Ashpalt
I had a 300 foot asphalt driveway installed last October and now with spring there is grass growing up thru it, this is causing the asphalt to push up. Is this a common occurance or an installation error issue? Any Suggestions.
Old 04-23-08, 10:16 AM
T
Received 2 Upvotes on 2 Posts
Is it Bermuda grass that is growing through asphalt. It has a reputation for that. Kill grass immediately with herbicide to prevent roots from taking a toll on the asphalt. You will have to be consistent and persistent in your battle against grass growing through asphalt.
Old 04-23-08, 02:05 PM
Received 800 Upvotes on 703 Posts
Welcome to the forums!
Did they do the proper site prep - gravel/slate base? How thick is the asphalt? There are a few unscupulous paving companies around here that will cheat and pave with a thin coat of asphalt and build up the edges to look thicker
Old 04-23-08, 06:32 PM
Received 1,248 Upvotes on 1,192 Posts
Grass will eventually grow through, but this seems pretty quick. I'd call the installer and see what they say.
