cracks in stucco
cracks in stucco
is it normal for an 8 year old home to develope large cracks that radiate from the corners of all doorways and window openings. The city plaaning manager claims that this condition is called "checking", and that it is quite normal. please advise
Welcome to the forums!
I've never repainted a stucco house that didn't have some cracks in the stucco. As long as they are minor, it's no big deal, I usually just fill them with caulk and then paint
If the cracks are wide, it might indicate a settling problem.
Is your house wood framed? or block construction?
It is normal for an incorrectly lathed project, yes. If all windows and doors are cased, and expansion joints are used, there will little to no cracking. Your best bet is to patch the cracks are coat the building with an elastomeric.
Control joints should extend from the upper sides of all windows and doors. Simple as that.
There are ways to work it into the design or lessen the need, but those areas create a plane of weakness and will always crack, if it is going to crack at all.
