Bolting Lamp to Concrete
Old 07-01-08, 06:43 PM
Received 1 Upvote on 1 Post
I am wondering what the most effective way of bolting down an outdoor lamp (5-6' high; not too heavy) to a flat slab of concrete in the ground. The lamp comes with little bolts but I'm thinking I need something to maybe go completely through the concrete.
And, I'm stupid enough to need details on drilling a hole in concrete, type of bolt I should get, etc.
Thanks to all.
Old 07-01-08, 07:39 PM
nap's Avatar
nap
nap is offline
New Member
Received 2 Upvotes on 2 Posts
I would use either a wedge anchor or a sleeve anchor
drilling a hole will take either a hammer drill with the proper size masonry bit or a star chisel of the proper size and hammer.
You will not need to drill through the concrete.
for a nice touch, once you get the anchors tight, you can remove the nuts used to tighten them, cut the studs down and use an acorn nut for a nice finished touch.
