Mixing brick and cinder block
Old 07-01-08, 09:47 PM
R
Ok, I'll admit it. I hate to see anything go to waste. As a result I now have enough bricks and cinder blocks that were bound for the dumpster to build a small structure (~3'x5'x5'h). I've tried my hand at all the other trades, but not masonry.
The project isn't critical and more for the experience than anything else. I've poured a reinforced concrete footing that's not going anywhere. Haven't decided on a 'design' yet.
My question is can I mix the two in the same structure? Either by alternating courses of each or alternating in the same course. Are expansion rates different between the two materials a concern and would the type of mortar used be an issue.
Also thoughts on wire reinforcing would be appreciated. "First time out" in this trade endeavor. Thanks!
Old 07-02-08, 06:51 AM
Received 1 Upvote on 1 Post
If you are mixing them in the same wall, the minor differences are of no importance.
If you are building two separate layers (wythes), that is a different story if it is a very tall building.
Archtects frequently use the different materials (brick and block) for design and accents.
Old 07-03-08, 09:14 AM
R
Thanks!
Sorry for delay - I'Net problems here.
Thanks for the information. No lives, but only my ego on the line with this project. If I can mix the two materials together I can get more 'volume'. Now that I know it'll work I just need to 'dry stack' and work a suitable design.
Thanks for all, including the new term! Appreciate you taking the time.
Old 07-03-08, 10:05 AM
Installations, Maintenance and Repairs.
Are you trying to seveal layers of block or brick to make a thicker wall?
If so, and you are thinking amout using surface bonding, you could have problems. - Even for a building as small as you propose.
Dick
