Relaying a brick patio...
Old 07-06-08, 01:48 PM
D
Just about to relay a monoblock (interlocking brick) patio and I need some advice on what and how much base to lay for it.
It will be about 5m x 4m and will only have foot traffic...no vehicles or anything heavy.
Do I need to use hardcore and then sand for the base or is just sand sufficient?
What depth should I lay and what's the best way to edge it so that it won't separate?
Thanks
RG
Old 07-06-08, 02:12 PM
Received 1 Upvote on 1 Post
Why are you relaying the patio? - Did it settle?
If that is the case, you need to improve the base soil to eliminate future settlement.
The sand is to be a sttling bed and should be uncompacted and have a uniform thicknes of 1" or about 25 mm.
Old 07-06-08, 04:30 PM
D
I'm relaying it because it's currently matching the slight slope of the garden...I want to flatten it and also enlarge it on three sides.
Are you saying that I would only need to use sand?
RG
Old 07-10-08, 09:54 AM
P
If the patio has been there for a while (at least a few years) and been stable, I would recommend using the same base that was used originally.
If you wanted to make sure it was solid long term, I would recommend a DGA or 3/4" minus gravel (also called 'road base') in a minimum of 4" compacted before placing your 1" loose sand leveling bed.
Another alternative is to till 3 or 4 inches of your subgrade (soil) with portland cement and wet it as your base. That provides non-clay soils with sufficient stabilization, followed by your 1" sand leveling bed then pavers.
