*Help* Building up existing foundation?
Old 07-26-08, 10:16 PM
biketrax's Avatar
Received 4 Upvotes on 4 Posts
I have an 8 inch by 50 inch foundation I need to build up about 2 inch.( to match another a bit higher)
I plan to build a plywood frame. Next I plan to use a mixture of 50% cement and 30%-50% sand , then pour and level. Before hand I am going to rough up existing surface and put a few protruding threaded bolts for the project at hand.
Any advise I may be overlooking
Should I use any special cleaner on existing surface or just clean and rough out best I can?
thanks
Old 07-27-08, 05:28 AM
Speedwrench's Avatar
if you only need to go up about 2 in, use pressure treated 2x8 and anchor it to the existing foundation. portland and sand will not give you a strong foundation. that high a amount of portland will make it very brittle and easy to crack. if you insist on useing concrete use a more conventional mix but drill and anchor to the existing foundation befor pouring to allow your bolts to have the strength for a good hold down.
life begins when the kids leave home and the dog dies
Old 07-28-08, 10:25 PM
biketrax's Avatar
what would be the best mix?
If you dont agree with the portland and sand.what would be the best mixture.
Are you suggesting Quickcrete??
I was just trying to avoid the bigger stone (in that mixture) to try and get a smoother finish.
thanks
