Fasten sign to brick post
Old 10-03-08, 10:35 AM
B
hello, I have carved and painted a sign. I want to fasten the sign to a brick exterior column. The sign weighs just a few pounds. What are my options? Could I use a construction adhesive instead of screws/nails?
Thanks in advance.
Old 10-03-08, 10:54 AM
Gunguy45's Avatar
Super Moderator
Received 6 Upvotes on 6 Posts
You probably could, if you have a way to temporarily hold it while the adhesive sets.
But....
I would recommend some sort of mechanical fastener like Tapcon screws instead. If it ever needed to be removed, the adhesive would look bad, and might damage the sign or the brick while trying to remove it. 2 small screw holes would be much easier to repair than the big marks left by adhesive.
If the wood is thick enough, you could countersink and plug the screw holes with some decorative wood buttons. Or just paint the screw heads with something to camouflage them.
Old 10-04-08, 05:26 AM
W
Received 61 Upvotes on 53 Posts
Sign
Place the screws in the mortar joints. Easier to drill and easier to repair the holes if you want to remove the sign later.
Old 10-08-08, 06:33 AM
B
Thanks
Thanks for the responses. I'll go with tapcon screws in mortar.
