Paver going--pattern question
Old 11-26-08, 08:42 AM
W
So far so good, we're putting in our pavers now (4 X 6 Holland bricks) and have a queston:
Our walkway shape is basically "L" shaped with the shorter end going up to the house and the longer end running along the house. Rather than try for a 90 degree turn we went with a curved or gradual turn.
Does anyone have any tips on adapting a herringbone pattern so that it works (without tons of cuts) in a curving installation?
Thanks
Old 11-26-08, 09:00 AM
Received 1 Upvote on 1 Post
Herringbone pattern
With a herringbone pattern, you will always have cuts. The good thing is that is the strongest and most stable pattern.
You can use either a hand splitter and split as and where you lay them or you can set up a saw and saw them. Most people get unnessarily worried about not having a smooth edge towardsaw them, but that is not a problem. You cut the pieces out of the other cut portion or a fresh paver. Because you have a curve there will be little repetition in the curved section.
I have seen many contractors use a gas power saw and saw off the excess beyond a marked line. This method is good for odd shaped paver shapes and complex patterns. The edging is then put in, sand spread the the surface compacted ans swept.
Dick
