Cutting concrete block wall
Old 01-31-09, 04:43 PM
C
Received 1 Upvote on 1 Post
I have a concrete block wall 3' high, and I need to cut out a section about 4-5 feet wide so I can drive a garden tractor thru it.
What would be the best way to cut this... should I just rent a rotary saw with a diamond blade and make sure I'm cutting thru the hollow areas of the block?
Old 01-31-09, 05:23 PM
Speedwrench's Avatar
rent a saw with the diamond blade and don't worry about the hollows and use a crayon or lumber marker so the line doesn't wash off. you might want to consider using a 1x4 and tapconing it to the wall for a straight edge to help with the cut for a good straight line. i would cut it about 3-in wider on each side and frame in and pour concrete on each edge to reinforce the blocks after they dry.
that also will give you a better looking cut.
life begins when the kids leve home and the dog dies.
