Applying mosaics to stucco walls
Old 02-11-09, 08:32 AM
Question Applying mosaics to stucco walls
Hi, I have an outside, ugly stucco wall that I would like to improve by applying mosaics (a combination of tile, glass, stone, etc..) and I am not sure how to do this. Can someone please tell me what materials I would need? I live in PA so the wall is exposed to the winter elements. Thanks in advance,
Jan
Old 02-11-09, 02:11 PM
T
What is the finish? Smooth, rough, painted, etc.
Old 02-12-09, 08:06 PM
The stucco is a painted rough surface. Thanks.
Jan
Old 02-12-09, 08:08 PM
T
You will have to remove the paint totally, then you can use thinset.
Old 02-13-09, 01:09 PM
Thanks. Will I need to apply any type of sealant after the mosaics are set?
Old 02-13-09, 02:39 PM
T
You should, either a surface or a penetrating one. Surface if you want wet look, penetrating if you don't.
Old 02-13-09, 05:18 PM
OK, thanks. What do you recommend I use to remove the paint from the stucco wall? I forgot to ask you. Also, do I have to use grout in between my mosaic tiles, stones, glass pieces? Just wondering. And is "thinset" a type of mortar with adhesive? Can I buy it at Home Depot?
Old 02-13-09, 05:33 PM
T
It will depend upon the paint, but nothing short of a sand blaster is going to do it easily. A wire wheel on a grinder will do it, but it will take a while.
Yes you will want to grout the joints and yes, big box stores sell thinset in the tile dept.
Old 02-14-09, 01:59 PM
Thank you so much! I greatly appreciate your helpful information!!! : )
Old 01-31-10, 11:15 AM
T
Mosaic on stucco
Mosaic on stucco
Actually I have a further question for tscarborough...
I have a stucco home. The stucco is lightly textured and the color is in the stucco itself. How do I go about adhering glass and ceramic tiles in a freeform mosaic design? It will be under a covered porch. Only line driven rain would get to it and that is rare.
Old 02-01-10, 08:34 AM
T
The same way; thinset will work just fine.
