Parging inside of exterior wall
Old 04-02-09, 07:38 PM
After removing the lath and plaster I found that the wall was originally parged on the interior. Some areas of the parging has come off. Can I just fill in the spaces with mortar or should I use a parging mix. The areas to be covered are pretty small a few gaps here and there. This will be covered over with drywall. Thanks
Old 04-05-09, 09:58 AM
if the exterior veneer is intact, and the interior is covered with sheet rock, you don't need to do anything, really.
but if it will help you sleep at night, take a wire brush and a soft broom or a shop-vac to the area, get some type 's' or type 'n' mortar, and smear it on there.
