cracks in basement floor
have some cracks in my basement floor...had some water seepage this year after all the snow and rain....use hydro cement to temp stop it....want to put tile down...can i open the cracks and fill with cement or something else....would using some sealer on top help.....live in the north..so we get all kinds of weather...
cracks in basement flooor
The reason that I want to remove the patching, is to smooth out the floor.....if using the hydro cement to fill the cracks, fill I can do that...but I used it over the cracks to stop the leaks....I believe I should open the cracks and then fill and smooth over.....but what can I use to seal that more...a paint or sealant or something
Temporarily Suspended
I would just chip away the excess cement instead of removing all of the hydro cement. I can't see taking a chance on doing it a second time when it's already working. I wouldn't add a sealer on top of it either. I don't think it will add to the strength of the cement.
