uneven stone patio
uneven stone patio
previous homeowner built a flagstone patio, set in mortar..the patio is very uneven, hence, difficult to use..can i do a levelling course of concrete/other material to level the surface?
i'd prefer not to cover too much of the stone, because it is pretty, but very uneven..are there any transparent alternatives to a concrete levelling course?
Are you talking about the mortar joints in between the flag stone are not full joints flush to the top surface of the flagstone??
So whats the real point here I'm confused.. To Lee a patio is from below or above in materials. Above covers the stone.
uneven patio
and i'm confused by the confusion..the surface of my stone patio is uneven..because the stone is not flat, i can see the difficulty in making a flat surface, but i find the inconvenience of an irregular surface renders my patio largely unusable..so, my question is, is there a way to make the surface flat?
certainly, a levelling course of cement would do that, but it would cover most of the stone..is there any kind of transparent material i could pour or place to smooth out the surface?..or am i stuck with either covering most of the stone with a concrete topping or simply removing it and starting over?
finally, if i wind up trying to put a levelling course of cement, can i ensure this thin top course bonds with what's below it?
