Monolithic vs "Conventional" Slab
I am building a 10' x 12', possibly 10' x 16', garden/shop shed in NC. Frost level is 12".
In your opinion would a "conventional" 4" thick slab work or should I pour a monolithic slab with the edges down at least 12"? Or a "conventional" that is thinner or thicker than 4"?
Not sure how much frost heave will really affect a shed foundation.
We also probably only have <30 days of freezing temps here.
Also, what's the best base material for either method? 3/4" drainage stone, crusher run?
Also will be lining the outside perimeter with some drainage pipe.
Thanks
Thanks
That is a pretty small building, so you can get away with more.
Since you have a 2' frost depth one option is a stem wall on a footing (block or concrete). Inside of the stem wall, you can pour a 4" floating slab (wire mesh and not tied to the walls) on a compacted base. The height of the stem can be determined by your use.
If it is a utility building, you may wish to have the top of the stem 4"-6" above the finished floor to provide a "clean" exposed concrete/block wall surface that allows easy cleaning and get the wood a little higher above the soil and rot/moisture. This also allows you to slab the interior slab slightly for drainage and cleaning.
We have colder temperatures, but this is preferred around here.
You can always build with a monolithic slab/structural floor (reinforced) and let it float with any soil heaves.
Dick
Dick
The frost level is only 12".
So, it would be ok if the floor floats with any frost heaves? I assume the reinforcement would need to include rebar and wire mesh?
Does it need to be a monolithic pour if the intent is to let it float or would a reinforced 4" slab be ok? Or 5" or 6"?
The heaviest piece of equipment I would have potentially would be a zero turn mower, although I don't even have one right now.
Also, I'm looking at going with one of those 1yd rental trailers for delivery. Since the slab will call for an amount above that, can I make the pour in two trips without the first batch setting up before I can pour the second. I live about 3 miles from the site.
Thanks for the response
