Drain tile questions for retaining wall installation.
Old 07-20-09, 05:29 AM
T
Question Drain tile questions for retaining wall installation.
I've got a couple of questions about installing drainage tile behind a retaining wall:
1. Do I install the drainage tile directly on the ground at the lowest point of my trench below the compacted base. Or do I install the drainage tile on top of the compacted base. My trench is 12” deep. I plan to add 6” of compacted base. My drainage tile is 4”
2. I have a wall which runs 16' and then turns 90 degrees and runs up a slope about 9'. I am going to run drain tile the entire length of the 16' wall (which is at the bottom of the slope). I need to pass the drain tile running along the 16' wall underneath the perpendicular wall on the right side to direct water away from the wall. I am not sure how to pass the drain tile underneath the wall. Could someone offer some guidance?
Old 07-23-09, 06:02 AM
Received 800 Upvotes on 703 Posts
I'm not an expert in this field but since no one else has replied.....
The drain tile should go at the bottom of the wall with gravel above it.
If I understand correctly, there should be a piece of hard [pvc] pipe in the footer [or maybe bottom section of the wall] and the drain tile would either be connected to it or pass thru it.
