Cinderblock chimney deteriorating
Old 07-26-09, 10:46 PM
B
I'm pressure-washing my house to get ready to paint and large chunks of my cinderblock chimney are coming off with a small amount of water pressure. The paint is also peeling over the entire area. Three questions: What is causing this, what should I do to repair it and how do I prevent the problem? Thanks for any advice.
Old 07-26-09, 11:22 PM
2
I'm assuming there is paint on the chimney. You can repair it with mortar. If this chimney had a wood/coal stove hooked into it. Replace chimney. It would be wise to get a chimney video scan to see if there are cracks in the flues. If the chimney Has no flues replace it.
Old 07-27-09, 08:55 AM
B
Yes it is painted, and large pieces are coming off. Do I apply a coating of mortar to the exterior surface? What about painting it? FYI- the chimney is now used for venting a gas fireplace.
