6' deep by 36" diameter footer hole
I need to put in a footer for a small wind turbine. The specs call for 36" in diameter by 6' deep. I have a 23 horse Kubota tractor which is too small for an auger big enough to do this easily and I'd prefer not to dig this by hand. What are my other options?????
You Need a standard backhoe. What the size of the wind turbine ? I wouldn't think the hole is going to be filled solid with Crete.If so I wonder what a wider less deep base would be more appropriate As long as the base doesn't rip out of the Crete a wider Crete footprint is usually the norm on my construction sites.
Need to remind you anything you dig in a hole past your waste needs/ has to be braced. Saw men lost in ditches already
This has nothing to do with the question, but hopefully there is a well engineered connection that is tied to rebar reinforcement in the concrete. I was recently party to a similar project that had failed due to poor engineering and construction... the cement footings literally snapped like twigs during a high wind (wind shear during a thunderstorm) due to the lack of reinforcement and tie-in connections with the footers. TIMBER!
Hi Pecos. Never saw one that long/wide for a bobcat. They go as wide as 30" but He needs to reach 6 foot and what happens when a rock is hit?? Round holes that are dug like this one come on a fairly big ribber tire machine Bigger than a backhoe.
Not that we've heard back...but I think I'd be talking to the local utility company or a company that does contract work for them. Out here the PoCo will send there trucks out for all sorts of things like this.
