concrete block foundation cracks
Old 08-14-09, 05:40 AM
T
Question concrete block foundation cracks
I have a block foundation which has cracks where the mortar should be. What is the best way to fill in the cracks and what should I use to do so?
Thank you for your help.
Old 08-16-09, 09:56 PM
2
grind out the joint with a diamond grinder and mix some mortar up and point the joint.
you can use a small chisel instead of a grinder, The joint should be no less then 3/8 deep to hold new mortar
Old 08-17-09, 08:05 AM
B
Please make sure you address the problem outside of the home before doing this or you'll just be doing it again. Check for proper grading and drainage.
