dry time for quickrete mortar mix
Old 08-25-09, 10:48 AM
F
Need to do some repairs on my brick walkway, and can't seem to find any info on the dry time for quickrete mortar mix. Reason I ask is that the area that I am fixing gets hit with the sprinklers, so I don't want to get it wet before it is set.
Thanks!
Matt
Old 08-25-09, 11:09 AM
Gunguy45's Avatar
Super Moderator
Received 7 Upvotes on 7 Posts
A lot depends on temp, humidity, etc. When used for a block wall or similar its pretty solidly cured in just a few hours...ground contact maybe longer.
Turn the sprinklers off for 1 day and you should be more than fine.
No expert, just what I've found to be true for my few small projects.
Old 08-25-09, 11:36 AM
T
As long as it has set enough that it won't wash away, it won't hurt it to get wet (it will help it, in fact).
Old 08-25-09, 11:56 AM
F
great. Thanks guys.
Matt
