caulk to seal wire in concrete
Old 12-04-09, 12:06 PM
H
I recently had an irrigation system installed, and the contractor drilled a hole in the foundation so the electrical wire for the rain sensor could get into the basement. What type of caulk should I use to seal around the wire coming into the foundation?
Thanks!
Old 12-04-09, 12:58 PM
Gunguy45's Avatar
Super Moderator
Received 3 Votes on 3 Posts
No expert...but any good quality 100% silicone would probably be fine. I imagine the hole isn't that big...use some clear GE 100% silicone..smooth it off on the outside so water is shed off..and you should be fine...
Blow/vacuum any dust out..and pump it in. Do both ends.
I'm assuming the hole is above the soil line of course.
Old 12-04-09, 01:32 PM
H
Yeah, the hole is above ground. I wasn't sure if the silicone would adhere well to the cement, but I'm not sure if there is a better alternative.
Thanks for the advice!
Old 12-04-09, 04:14 PM
Received 300 Votes on 266 Posts
A butyl caulk will also work but as long as the dust is removed, most any caulk would work. IF it's an area that gets painted - don't use silicone!
Old 12-04-09, 07:48 PM
If you want it to look like brick mortar use concrete repair caulking which is a butyl based gray caulk.
Old 12-12-09, 09:18 PM
Great Stuff should work, it may be unsightly depending on the location, but I used it for a new water line a couple years ago. It was in a back room, and below ground level, but no problems to date.
