pouring over an old slab
I have some 29.2'x16" bar joist that I want to use to expand my old carport that was poured back in the late 70's. Slab is in good condition about 14x16. I want to expand the size (20x30) and do a complete pour over the old slab (to get more elevation). If I am understanding right, I need to prepare the area and put a vapor barrier over the whole pour area, including the old slab?
Temporarily Suspended
Is that a studebaker hawk or a studebaker lark?
I don't know about the vapor barrier. What's more important is how much height do you want to add? As far as I know, you need to go at least 2 or 3 inches higher.
I think you would need the vapor barrier under the new addition for sure. If the old slab does not draw moisture to the surface now it probably does not need a vapor barrier under it.
But the plastic is cheap and it won't hurt anything for it to be over the old slab. I would put it under the whole thing and be sure you allow for proper drainage on the new addition.
