What mortar to repair a stone wall?
Here's a picture - you can see that there was some sort of mortar in back, but apparently it wasn't a "forever mix".
http://imgur.com/XP90v.jpg
Thanks
JimR
Use a mortar mix
You need something with lime and no large aggregate. Here's a link describing different mortar mixes:
What is Mortar Mix?
Also, I saw some stone masons on one of the TV shows crush the old mortar with a hammer and mix it into the new mortar to help match the color. I can't tell from the photo if your mortar is a special color or even shows that much, but if it does, this might help.
Good luck!
What is Mortar Mix?
Good luck!
