patio quotes
Old 05-06-10, 10:21 AM
T
patio quotes
I'm in Houston, Texas. I want to have a patio poured (12'x50'), adding two sidewalks (40' and 20'), and a 10x12 slab for a shed.
What should I be looking for on concrete, concrete psi, rebar, etc..
Thanks
Old 05-16-10, 02:25 PM
L
You want at least 4 inches of concrete, 5" would make it even stronger.... psi at least 3000, no more than 4000... reinforced with 6"x6" wire mesh or 3/8" rebar 12"x12" would be good... if the area is virgin ground and not wet or soft its ok to dig down 4-5" and install the concrete, otherwise get down to hard dirt and install a gravel base, if the area needs alot of fill more than 12" the key is a solid base before the concrete is poured
Old 05-16-10, 09:29 PM
T
Thanks!
What's up with the 25 character minimum
