Brick Mailbox Design Question
I would like to build a brick mailbox like the one below. To get the layered effect I should use different width cylinder blocks in the core?
Thanks
Thanks
to get that effect just pack mortar behind them? When installing the top part that is corbled will I have any trouble with them falling down or the mortar should hold them and bond?
EDIT:
I found an article on gobrick.com. It appears that the brick can be corbelled about a 1/3 of its width and for further support to fill the cores in the brick with mortar?
EDIT:
I didn't see your location, but if you have any frost, you will need an appropriate base. Lots of frost and the project gets complicated.
Make sure your post office will approve and that you can remove and replace the $9.95 official mail box from your $300 enclosure
. Any snow plowing should be considered, plus, since we often don't own to the edge of the road, you might want to check with your town.
Our road is being worked on as I type and our boxes are being relocated.
FYI
Bud
FYI
Bud
im in nj. From what I read I have to dig down 36"? do i need a pad at that depth or just rock base then pad?
Yes, you will want a pad. You will need to contact Dig Safe, free, to have a locate done for gas, water, telephone, other, all marked. Sounds like a pain, but the real pain is the $5,000 fine for hitting a wire because you didn't call. And yes, even a shovel can cut a wire. As a contractor, I have no insurance if I don't call and I have worked at locations where there couldn't possible be a wire, but still called.
I used to live/work in Brick, so do contact your town office and get permission in writing, NJ does have strict codes. You do get some snow, hopefully they will be scared away by the looks of it.
One of the things contractors cringe at is seeing a porch lifted by frost because the posts were not installed properly or those concrete gate monuments when they are leaning to one side. You have a real mix in NJ, sandy shore and rocky north country, so your code people will know what you need.
Bud
Bud
