Walkway below grade
Old 08-12-10, 04:21 PM
W
Received 14 Upvotes on 12 Posts
Walkway below grade
Is there a rule of thumb, or a code requirement when it comes to how much difference there should be between a residential sidewalk and the lawn alongside?
I am installing forms to extend an existing sidewalk over a sloped section of lawn. I have one section (6') of sidewalk that will be about 4-5" below grade on one side and 4-5" above grade on the other. I can fill the low side a bit, but I would have to remove a large area of lawn to get the high side level with the walk.
Old 08-12-10, 06:11 PM
T
Anything over an inch or so on the uphill side should be either sloped at a less than 45 degree or faced. On the downhill side it should be less than an inch below finish grade and sloped away at 45 degree or less.
Old 08-13-10, 04:22 AM
Received 839 Upvotes on 736 Posts
Would landscape timbers work to hold back the soil on the high side?
