Re-anchoring brick collumns
Old 10-07-10, 07:10 PM
D
In replacing the patio cover I noticed that three of my brick collumns will rock to and fro if I push on them. They are approx 7 feet tall, 10" by 20" wide and deep. The mortar has broken about 2-4 bricks up from the ground. Is there some type of glue, filler, mortar that I can push into the cracks as I lean the collumns to create space? Something that will seal the seam and make the collumns solid again? If the collumns were hollow in the middle I could put a few rebars down the center and fill with cement, but they are solid all the way through. Any help is appreciated.
Old 10-08-10, 04:27 PM
The only thing that will make them solid again is a rebuild
