Move window in CBS home
Old 11-14-10, 05:38 AM
R
I want to move the window about a foot to the right. My question is when I cut the wall am I going to have to pour a concrete header? There is probably going to be a header (Lintel???? I think thats what its called) in place already, but if I cut past the end of it am I causeing a structural issue? The top of the wall should be a solid pour around the entire house and (Lintels?????) above all the doors and windows.
Old 11-14-10, 02:01 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
There will be a lintel, and as you suspect it will end shortly longer than the present window is wide. Not enough to move it a foot. Is this a monolithic pour or concrete block wall from the ground up or just on top of the windows?
Old 11-14-10, 04:45 PM
R
Concrete block and I believe the top foot of the wall is a solid pour.
Old 11-15-10, 04:31 AM
Received 821 Upvotes on 720 Posts
The top block [8"] might be lintel block with rebar but I'm pretty sure you'd still need a separate lintel above the opening, longer than the window is wide.
