Crack in interior of foundation wall
Old 11-29-10, 03:05 AM
NEsportsfan's Avatar
Hello!
There is a narrow but long crack in the interior of the foundation of the house. Is there a practical, inexpensive way to fix this? Wasn't sure if mixing some concrete would work to fill it in or not. Figured I should ask before I did this. Thank you much for any input.
Old 11-30-10, 02:04 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
You know better. Where's the pix?
Old 11-30-10, 05:09 PM
Sorry about that. It might be fun taking pics with a laptop webcam
Pictures by Chris_Hirschfeld - Photobucket
the crack is in the right side of the pic, it is diagonal.
Old 11-30-10, 05:35 PM
The crack is longer than that, but it doesn't get any wider than that. This foundation was poured in 1969.
Old 11-30-10, 06:15 PM
C
is it leaking ? ......................................
Old 11-30-10, 06:54 PM
No water leakage from there. There is water leakage from a different spot on the other side of the basement. Thinking of doing a French drain along the foundation when Spring comes if I can swing it (rental of Bobcat and buying the other stuff.).
Old 12-01-10, 03:44 AM
P
I've patched similar cracks with hydraulic cement. Be sure to follow preparation directions on the container.
Old 12-01-10, 02:54 PM
Thank you much Pecos!!!!!!!!!!!!
Old 12-23-10, 03:21 PM
B
patching crack
what i would do is v the crack dig out lose material and get some backer rod and stuff in the crack use hyd. cement or portland and sand kind of on the stiff side
Old 12-24-10, 11:08 AM
Don't think I can fit a screwdriver into it.
