cold weather concrete ?
Old 11-30-10, 08:37 AM
C
guys. i have a problem.
comcast, right now, is installing this big ugly box right outside my kitchen window. potential buyers are not going to like seeing that.
so i am thinking i could put a nice looking fence to block it, and the 2 other boxs there. but its in the 30s & 40s right now.
is there a sack of cement that i could in these temps, for fence posts ?
thanx
Old 11-30-10, 05:28 PM
P
Temporarily Suspended
If the fence is wood, you don't need cement.
Old 11-30-10, 06:11 PM
C
yes, it would be wood. something that looks nice, and not tall. thanx
Old 12-01-10, 03:48 AM
P
At those temps any concrete would work. The concrete will be below ground right? As long as the ground isn't frozen solid, the concrete will set up. Even if it got down in the 20s the night you poured it, you'd be okay.
Old 12-01-10, 08:30 AM
P
Just dig to the frost line & forget about the cement.
Old 12-01-10, 08:49 AM
C
this is right outside my kitchen window, and is closer than it looks in this pic.
the one that looks like a port-a-potty, is the new one. used to be like the right one.
Old 12-01-10, 09:25 AM
Gunguy45's Avatar
Super Moderator
Received 6 Upvotes on 6 Posts
One thing to consider..there is probably a utility easement around there. If you block access, they may tear it down and not have to replace it.
You also need to call your local wire marking service (there's a toll free nationwide number). Even though it's been marked, it needs to be done again under your name, otherwise you could be responsible for repairs. Be very careful..there is probably 480V leading to the big transformer...but they should be pretty deep.
Personally...I'd just plant a few shrubs.
Old 12-01-10, 10:41 AM
C
if i end up putting a fence there, i would make it removable. somehow.
