attach wood to block foundation (for door frame)
Old 12-13-10, 10:07 AM
K
Just had a small block foundation put under a porch.
Mason left access as it leads to basement. Need to get a wood frame and door in place before weather gets any colder.
Tapcons?
Mortar? (minimum outside temp?)
Old 12-13-10, 11:16 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
If it is solid concrete, I would use split drive anchors. See: Split Drive Anchors - Concrete Fasteners.com
All that will be exposed is the round head. No snagging on clothing, etc.
Old 12-14-10, 08:37 AM
Tapcons, I've used a power hammer (the kind with the powder cartridge) for a lot of my constuction in the basement. You could also use the hardened nails, like you would use with the power hammer, with a regular hammer. Wear safty goggles, for sure, with any method!
Old 12-15-10, 09:43 AM
K
thanks
Its not solid concrete so I will be using tapcons
