drill hole through foundation
I need to drill a hole through a concrete foundation under an exterior wall (above ground surface) just big enough to run a garden hose through. I'm not sure, off hand, of the thickness of the foundation wall, but I believe it's probably 8 inches or so at the most. I'd like it to be a relatively clean and round-looking hole with a relatively smooth inside surface. What's probably gonna be a the proper tool to accomplish this without much trouble/effort? A certain size hammer drill with a particular type of bit, maybe? Or something else, any suggestions appreciated.
I would stop at one of the rental shops and look at a one day or half day rental of an electric hammer drill. They will have the necessary bit and be able to advise on the correct size.
Bud
Bud
And you want a rotary hammer... not a little 1/2" hammer drill. With the size bit you will be using, they will surely suggest a 1 1/2" rotary hammer.
Okay great, thanks. And would I probably want to drill a smaller hole (pilot hole) through first, before drilling the final (probably 1 1/4" or so size hole)?
Likely a good idea. Also consider drilling from both sides with your larger bit. Concrete has a tendency to blow out when drilled from the back side. That way you will get a cleaner hole on both the inside and out.
For a garden hose, you probably won't need more than a 7/8 to 1" bit for a snug fit, making sealing from the elements easier. I just did this in a remodel for a raised dehumidifier the customer wanted to evacuate to the atmosphere, and a 7/8 worked fine.
You're right there'd be no reason to make the hole bigger than need be. However, I was thinking of maybe inserting short piece of pvc pipe (a length the same width as the foundation) into the hole to serve as sort of a liner for the passage. Not sure why though. So probably won't.
rent a hammer drill,,, you'll only need 1 size bit & ( to me ) placing the pvc liner's a good idea,,, mark your hole & either start from the outside & go all the way thru OR mark both sides of the wall - start outside - drill 5" - go inside & drill 3",,, when the holes approach each other there will be a tendency for the bit to ' grab ' & lock up so watch out. good luck !
the smoothest hole's made w/a diamond core drill but its VERY unlikely you can rent a weka ( brand ) drill.
rent a hammer drill,,, you'll only need 1 size bit & ( to me ) placing the pvc liner's a good idea,,, mark your hole & either start from the outside & go all the way thru OR mark both sides of the wall - start outside - drill 5" - go inside & drill 3",,, when the holes approach each other there will be a tendency for the bit to ' grab ' & lock up so watch out. the smoothest hole's made w/a diamond core drill but its VERY unlikely you can rent a weka ( brand ) drill.
Matching holes from opposite sides of a wall would be near impossible without precise measurements. It would be a PITA anyway. I agree with running a 1/4" or so pilot through in one shot. THEN run your final bit from both ends. You won't have the grabbing, either. Should be a smooth bore if it follows the pilot.
