Cracking in Brick/mortar, should I avoid this house?
Old 03-17-11, 07:42 AM
B
Unhappy Cracking in Brick/mortar, should I avoid this house?
I came across a house I really like but the only issue I see is this cracking. Would this keep you from buying the house?
Would this be an expensive repair?
I really appreciate your help!
Uploaded with ImageShack.us
Old 03-17-11, 02:16 PM
N
It looks like that the foundation is sitting down on one side and it's not an inexpensive fix. Make sure you get the right contractor to give the right estimate.
Old 03-17-11, 02:54 PM
Received 1 Upvote on 1 Post
It sure looks like a foundation problem where the settlement/movement causes cracks. Probably 2 different foundations or just one cracked foundation that leads to differential settlement.
If the foundation problems can be corrected, any brick left can be tuck pointed.
A contractor may not be the best choice since once you start with him, you have no idea of the cause and no control over the "repair" cost.
Dick
