cleaning cement block foundation
Old 03-19-11, 05:48 PM
B
Question cleaning cement block foundation
It's the type of block with the uneven, rock-like? surface. After 100 years it has darkened in places to almost black. Will power washing clean that off? Suggestions? Thanks! Bobbr
Old 03-20-11, 04:13 AM
Received 871 Upvotes on 762 Posts
You need to be careful with a pressure washer, while the block might withstand the pressure ok, you don't want to blast the mortar out of the joints. A bleach/water solution will remove any mildew, TSP or maybe a laundry detergent should remove any other type of grime. I'd wet the block, spray on the cleaning agent with a pump up garden sprayer and then carefully rinse with the PWer. A garden hose would also work. A scrub brush or old broom might be beneficial on the stubborn spots.
Old 03-20-11, 10:38 AM
B
Good point re the mortar. Thanks, I'll try out your advice. Bobbr
