Help with terrible concrete sealer odor
Old 05-23-11, 08:26 PM
G
I made the mistake of sealing an interior concrete office floor with exterior oil-based concrete sealer and the odor is intolerable. It does not seem to have dissipated in 2 weeks. Any ideas? I'd repaint it with something (it must be clear) to cover it if would help. I'm pretty desperate.
Old 05-24-11, 05:09 AM
P
The odor is from the solvent in the sealer. If it's still there after 2 weeks, you probably applied it much too thickly, or it's puddled down in the joints. If it's applied too thickly, the top skins over but the rest of it is still wet (the solvent can't evaporate as it's supposed to.)
Sealer should be applied as thinly as possible. Thicker is definitely NOT better. If you have fabric or carpet in the area, I'm sure that's holding some of the odor as well. I'd get some dryers and exhaust fans to try to get the odor out of the house, as well as some air-fresheners to mask the smell until it's gone.
Old 05-24-11, 05:43 AM
Tolyn Ironhand's Avatar
Received 860 Upvotes on 723 Posts
Not sure if this is a home office or a office building but getting some fresh air somehow would be very helpful.
Old 05-24-11, 09:16 AM
Received 1,262 Upvotes on 1,203 Posts
Odors are particulate and moving air across the floor will speed up the rate of loss of the particles and thus, cause the odor to disappear more quickly
