Using Recyled Asphalt - How to Harden Up Surface.
Old 08-15-11, 08:55 AM
I have put down 6 semi-loads of recycled asphalt from a highway resurface project. It has been down for 2 summers. It is starting to harden up very good in places. I would like to harden up the whole drive way, (100 yards long x 10 feet). Any suggestions?
I constantly drive over it in various places to pack down. It there a way or chemical to put over it to speed the harden process up? Thanks.
Old 08-15-11, 09:02 AM
Received 1,248 Upvotes on 1,192 Posts
Welcome to the forums
Was this ever compacted?
Old 08-15-11, 11:04 AM
Received 800 Upvotes on 703 Posts
Perhaps a pic or two would help - http://www.doityourself.com/forum/el...your-post.html
If it's fairly smooth, maybe a coat of sealer would help ??
Old 08-15-11, 05:57 PM
P
I don't think recycled asphalt is intended to harden like fresh asphalt.. it is simply ground up and used as fill. To harden it, I would think it would have to be re-melted so the tar is sticky again and then roller compacted like they do with fresh paving. I could be wrong.
Old 08-16-11, 06:40 PM
D
Received 1 Upvote on 1 Post
I think you are on the tight track, Pecos.
