concrete drive
Old 08-18-11, 05:40 AM
L
concrete drive
Hi
I am extending my drive, and have laid 3.6cube but came up way short of what i need!! can anyone help me with how much i need to complete, i dont have anywhere else to put excess concrete so dont want to go way over the top, but at the same point i dont want to be way short...again lol
cheers.
Old 08-18-11, 07:34 AM
Gunguy45's Avatar
Super Moderator
Received 6 Upvotes on 6 Posts
You'll need to tell us what those numbers are....centimeters, inches, feet? And how thick is the slab?
Old 08-18-11, 08:38 AM
Received 1,248 Upvotes on 1,192 Posts
The math is easy if you have the dimensions - length x width x thickness = the number of cubic units of material you need
Old 08-18-11, 04:11 PM
Received 800 Upvotes on 703 Posts
If I'm not mistaken, 1 yard of concrete will fill 88 sq ft at 3.5"-4" thick.
Old 08-18-11, 04:47 PM
Tolyn Ironhand's Avatar
Received 811 Upvotes on 683 Posts
I heard it was 70 sq ft per yard @ 3.5-4" thick.
Maybe that is with extra because according to the math:
1 yard should be 27 cubic feet
27 cubic feet sliced into 4" x 12" x 12" slabs = 81
Old 08-18-11, 05:32 PM
L
the numbers are cm , the slab will be 100mm thick
Old 08-18-11, 05:50 PM
D
Received 1 Upvote on 1 Post
That can't be calculated without angles on the corners and the radius.
Old 08-18-11, 08:11 PM
Ok boys here is the conversion
4180cm = 137.1'
5200cm = 170.6'
2750cm = 90.2'
1500cm = 49.2'
thickness of 100mm or 10cm = .32' or about 4"
This is one very large slab!!! Are you sure you didn't mean mm on your measurements?
If I was calculating per yard, your looking at about 154 yards of concrete which would be about 20 trucks in the US.
Old 08-19-11, 12:59 PM
I agree with Tolyn, we need to check the units here because the magnitudes of the values aren't making sense.
Old 08-20-11, 02:43 AM
L
i'm of the opinion that it should be measured form the longest width and the longest length, i think 1 cubic mtr would scrape it, but as i say, i dont want to come up short, but also dont want too much overs.
the measurements are mtr, ie 1.5mtr by 5.2mtr
hope that helps
Old 08-22-11, 08:02 AM
Meters? Can't be, your measurements would all be exceeding a kilometer on each side.
Old 08-22-11, 08:19 AM
Gunguy45's Avatar
Super Moderator
It's mm in the original measurements...not cm. Thats what he meant by 1.5m by 5.2m in post #10
So...4.18m, 5.2m, 2.75m, and 1.5m are the correct labels on the drawing with a thickness of .1m
Old 08-22-11, 11:33 AM
Ah, that makes sense
1.5 m x 5.2 m x .1 m = .78 m
Old 08-24-11, 04:52 AM
L
so to make sure, the thickness as .1 is 100mm which gives me a total of .78 cubic mtrs, which i think they only do .5 .6 or 1.0
appreciate all the help guys
