Installing steel angle header in concrete wall
Old 08-19-11, 03:41 PM
C
Is it OK to tapcon the steel angle directly to the concrete or should the steel have a barrier from the concrete? Maybe a sill gasket or even poly? Anyone have some thoughts?
Thanks....
Old 08-19-11, 05:35 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
I thought we'd already been here. If it is a lintel it will need support on both ends. No connection is made between the lintel and concrete.
Old 08-20-11, 02:56 AM
C
Oh OK - that it had to be screwed into the concrete as well. What about between the steel angle and the concrete header? Can those 2 touch or should I use a sill gasket or something else so they don't touch?
Old 08-20-11, 04:47 AM
chandler's Avatar
I would use a sill gasket, mainly for air infiltration, but it couldn't hurt to separate the calcium in the concrete from the steel. Usually tar board is put over the steel to separate it, but that was long ago.
Old 08-20-11, 11:06 AM
C
rust paint before install too?
