How to enlarge hole through cinder block?
Old 11-07-11, 12:52 PM
Hi,
I need to enlarge a hole through cinder block from just below 1" to just above 1" diameter. How do I best go about this?
Two ways I have thought of are using a masonry drill bit in a regular power drill (I don't have a hammer drill). I though the power drill should be able to handle this job; it's not like drilling a totally new hole.
Alternatively, I could use a half-round rasp to make the hole larger. It'll take longer and is more tedious, but if it works then I'd be happy.
Any advice?
Thanks!
MM
Old 11-07-11, 01:47 PM
Gunguy45's Avatar
Super Moderator
Received 2 Votes on 2 Posts
Masonry bit and drill should work fine. They kind of self center because of the cutting edges being on the tip. Now, I assume it doesn't have to be exact? And you can drill from both sides?
Old 11-07-11, 02:06 PM
Yes on both accounts: it doesn't have to be exact, and I can drill from both sides.
Sounds good. So now where do I find a 1" drill bit for normal power drills...
Old 11-07-11, 03:21 PM
Gunguy45's Avatar
Super Moderator
You'll need a stepped shank masonry bit for it to fit a typical drill...you'll prob only find a 1/2" shank..so check your drill.
Might want to check a rental store...prob cheaper to rent the drill and/or bit for a couple of hours than to buy the bit.
Old 11-07-11, 05:30 PM
Received 236 Votes on 216 Posts
Check to see if Harbor Freight has a cheap bit you can use. Earlier this year I needed to bore some long 1" diameter holes through concrete. 12" long brand name bits were quite expensive so I got a couple packs of 12" bits from Harbor Freight. Because of the really cheap price I got a replacement set up front knowing I'd kill a bit but much to my surprise those cheapo bits are still going strong. I can't recall if the set of bits stepped down to 3/8" or 1/2" but it might be worth a look.
